It is currently Mon Sep 16, 2019 10:43 am
 Stage 2 descriptor word order
Post Stage 2 descriptor word order
I get colors and temperatures randomly with textures. should I finish one before moving to the next line, like first all the colors, then then smells, or can I randomly put down what popped into my head
I rarely get smells and tastes, can I leave them empty or go back to them?
Sun Aug 12, 2012 10:24 pm
Post Re: Stage 2 descriptor word order
Follow the instructions in the DVDs.
Sun Aug 12, 2012 11:24 pm
I just went through the DVD again, I'm missing it. I know later on sensory input is out down as it comes, could I be I'm getting multiple aspects in the beginning?
Mon Aug 13, 2012 12:27 am
Textures then colors.
Do not move on to the next category until you are finished with the previous.
I had a similar issue when I started, which sorted itself out with practice.
If a color pops in out of order, simply keep moving with textures or declare AOL if it elicits one.
Tick tock, go faster, that helps as well.
Mon Aug 13, 2012 12:39 am
Good, thank you sir
Mon Aug 13, 2012 2:04 am
Happy Thanksgiving to all.
I have been watching the Master Tips Disc 3 this evening. Ed says that we should start with colors because that is how our brain naturally processes information. However, I do not remember anything like that from the 4 disc set or Advanced Workshop back May.
After memorizing TCSTTS for S2, I am a little confused. Have the protocols evolved since the master tips disc set? Suggestions from Ed or the pros?
Thanks,
Chris
Wed Nov 21, 2012 10:29 pm
Yes, site-associated colors are usually the first sensory impressions to enter into conscious awareness as the viewer 'interrogates the signal line' in S2. However, forcing awareness of textures, up front, serves (to a good degree) as a substitute for decoding the motion-feeling component -- if the site is physical -- of the S1 ideogram. (Refer to the original CRV protocols).
Wed Nov 21, 2012 11:13 pm
[ Time : 0.121s | 13 Queries | GZIP : On ]
