It is currently Sat Apr 20, 2019 2:45 am
 Analytical sketch
Post Analytical sketch
I find myself over complicating the stage 3 analytic sketches. Does drawing the dimensions in a linear way mean that they need to be represented as lines one after another? How will i draw something that is 1) angled, cobbled, straight, wired
and 2) looped or circle, spherical, long, wide, outside and huge
I feel till the time i describe the dimensions I do fine but the minute i sketch the analytical bit, I spoil it all and the resultant site template is off, though the aspect exploration is correct.
Sun Sep 11, 2011 4:38 am
Post Re: Analytical sketch
Just look at a couple real world examples (meant not in an RV session). Physically LOOK at a lamp in your room with your eyeballs. List the dimensions that compose that lamp. Sketch the lamp while looking at it. Isn't it obvious how each dimension is put together to create the lamp?
You are doing the exact same thing in a remote viewing session except you aren't looking at anything and you don't know what you are sketching.
Sun Sep 11, 2011 11:31 am
As for the S.T., it is the same thing, but instead of correctly placing the lampshade in the correct physical position above the base, you are placing the lamp in the proper place in the room along with the couch and stack of girly magazines hidden underneath it.
There is no short-cut to getting good at this except hundreds of sessions.
Sun Sep 11, 2011 11:34 am
AMEN!!!! :D
-Jessie
Whether you think you can or cannot, you are right!
Mon Sep 12, 2011 12:44 am
[ Time : 0.112s | 13 Queries | GZIP : On ]
