It is currently Thu Jun 20, 2019 5:29 am
 Expanding a site template
Post Expanding a site template
This morning I completed what was for me a lengthy session. After it was completed I took a break before doing error checking, collating, summary and analysis. I felt it was a good session containing more data than I usually end up with.
When I was reviewing the site template I noticed something missing. The missing item was an entrance to what I believe to be an underground bunker or cave. I would like to explore this further. It does not make sense to be lacking an entrance unless it is a grave. I doubt that because I picked up on AI here.
I do study the work completed in the advanced projects area but sometimes that can get mind boggling at this stage of my learning.
Question: I understand that you can continue a session with elements of a site template but what if I want to explore something that does not appear on the site template? Is the session complete now or is it possible to continue? If so, what is the best way to label it? After it is completed would I add the new analytical sketch and S4 – AI, EI, T and I data to the Site Template or would this be independent from the original session?
Sat Feb 23, 2013 6:26 pm
Post Re: Expanding a site template
Session is finished -- you've completed an end-run around your lower/thinking mind, which has now obviously re-engaged.
Don't touch/alter anything!
Sat Feb 23, 2013 7:24 pm
You're not talking about items you already had in your S3's or S4's and simply forgot to repeat on the ST, right? Not sure if that could be rectified long after the session, but usually one trains to eliminate such mistakes before proceeding to examine follow-ups anyway.
Sat Feb 23, 2013 8:08 pm
Thank you Ed...I am moving on.
No kfa...this was not overlooked on my S4 data but thank you.
Steven
Sun Feb 24, 2013 1:27 am
[ Time : 0.127s | 11 Queries | GZIP : On ]
