It is currently Sun Jun 16, 2019 2:57 am
 Forgot What?
Post Forgot What?
If I do a session through the S.T., then during error checking I discover I have left off the S.T. important S4 data, for example "EI-worried" or may-be a motion arrow, what may be done at this point. (AI-screwed) add it in, do the session over, or what? Thanks for any reply. JH
Sat Jul 26, 2014 7:35 am
Post Re: Forgot What?
Once the site Template is 'finalized' it is finished, and it is out of structure to go back and 'fix' something.
Now, if you are still "in session" when doing the error trapping, then by all means put it in. However, once the word "Break" or "End" is written on the page it has been finalized, and 'fixing' anything is not permitted.
Sat Jul 26, 2014 7:44 am
Thanks Daing, My sessions of late have been off, including the above mentioned examples. Sometimes feel like a lost soldier. But, I'm about as stubborn as it gets, and not about to give up. To many things going on in the world to abandon my RV training. (even if a little thick at times.) Thanks.
Sat Jul 26, 2014 7:51 am
Do not worry about hitting the target, Jerry.
Hitting the target will only get consistent once you get consistent with a perfected structure; as well as duplicating said perfectness over 50 to 100 sessions.
Upon arrival therein, you will have to vary your target types well enough to stay sharp in hitting your target in said categories.
Sat Jul 26, 2014 7:58 am
If recorded/downloaded S4 session data was inadvertently omitted from the S.T., then it should be inserted therein upon discovery of its omission, regardless of session completion timestamp (unless it does not drop out as a result of error trapping). 'Editing,' i.e., inserting an S4 datum or data that you think you've 'edited out,' after a site template has been completed, is never permissible.
Sat Jul 26, 2014 8:16 am
[ Time : 0.087s | 11 Queries | GZIP : On ]
