It is currently Fri Mar 22, 2019 12:22 am
 question
Post question
In my target I have three site aspects X, A and B. I am executing aspect X that is lifeless object or a thing. No sound No voice. When I execute aspect X I hear sounds and voice from aspect A.
Should I write down the sounds and voice I hear from aspect A in the sensory, dimension colum and in T and I colum?
Paul
Fri May 08, 2015 5:52 pm
Post Re: question
What a mess...
We'll need to first dissect your question before we can go anywhere.
First: The site has three (only three?) key site aspects.
By convention, key site aspect X (designated by [X]) is the target.
Got that, so far?
Sun May 10, 2015 8:57 pm
Post Re: question
Sir thank you. Example I picked up only three aspects X, A and B. I am executing key site aspect X.
In the tangible column I get the impression- object, thing etc. In the I column I get the impression like manmade, fixed, Arranged, Shining, etc. Aspect X is about 10ft above.
Aspect A and B are life forms on grassy land below.
When I am executing key site aspect X, I strongly feel the impression of aspect A and aspect B like land, grass, persons, moving, freshness etc. Should I write down this data from A and B in the aspect X T&I column? Because there is strong motion with aspect A&B
Thank you Sir for your help
Paul
Mon May 11, 2015 12:01 pm
Post Re: question
Key aspect crossover data -- including S3 analytical sketch segments -- will almost always be present in the session (especially if the placement of your S3 freehand labels are immediately adjacent to two or more aspects). This can be very helpful, btw, in constructing the site template.
1. You cannot know, at any point in S2/S3/S4 if you are picking up data from another site aspect. If you believe otherwise, then you are thinking -- and thus have bombed the session.
2. Your last two sentences amount to non sequitur.
Mon May 11, 2015 8:59 pm
Post Re: question
Thank you Sir so much
Paul
Tue May 12, 2015 8:00 am
Post Re: question
In the future, post your RV session work so that it may be sliced and diced, accordingly.
Tue May 12, 2015 8:17 am
[ Time : 0.092s | 13 Queries | GZIP : On ]
