It is currently Mon Aug 19, 2019 6:10 pm
 Question for MultiLnV
Post Question for MultiLnV
Hi there MultiLnV
I was curious as to the end session command.
Upon reviewing the dvds Ed states that upon completion of the ST, you must take a break before data analysis so as to disconnect from the site.
Threfore should I write end at the end of my ST, or after I have completed my data analysis?
Does the end mean end of session and disconnect from the site or does it mean end of everything to do with this session as in no more to do??
Hope you get my drift!!
Fandangoman
Mon Apr 27, 2015 4:19 am
Post Re: Question for MultiLnV
Sorry I have been away. You can write break with date and time at the end of S.T. and wait a little while and do your summary or you can write End with the date and time and wait a little while and do your summary and analysis. At the end of S.T., you break if you know you will likely be doing follow up work. End it if you think you are done. If you decide when you end a session that you have to go back in, you can cross out the end.
In either case, officially ending or breaking a session, you should not do analysis until 10-20 mins after because you have to give your self time to disconnect.
Tue May 05, 2015 1:37 am
[ Time : 0.073s | 13 Queries | GZIP : On ]
