It is currently Sat Aug 24, 2019 2:04 pm
 Comments Please on DVD Disk 1 Target 4 with Homemade TRM
Post Comments Please on DVD Disk 1 Target 4 with Homemade TRM
This is a homemade target, substituting for the DVD Course Target 4 that I did incorrectly earlier. My current "do over" session completed site aspects X, A and B plus S.T., as specified in the DVD Course. My homemade TRM may not have been prepared correctly--it contains an arrow to the Target--(I thought that I had already deleted all TRM with these arrows, but this one slipped through). I intended the entire Eiffel Tower to be the target, but my arrow touched the vertical leg of the tower. The vertical legs on this side of the tower contain passenger elevators to the top, so I guess that's what my S.T. shows. Any help with protocols and structure will be very much appreciated. Thank you.
Wed Aug 20, 2014 8:46 pm
Post Re: Comments Please on DVD Disk 1 Target 4 with Homemade TRM
Let's get this settled first. Where are your TRNs written on your targeting material?
Thu Aug 21, 2014 7:11 am
Tiger74,
The TRN for this target is written on the backside, after I folded the piece of paper. This is an old target; on recent and new TRM I write the TRN in the margin next to, above or below the target photo itself. I will eliminate the photo jargon from my targets, leaving only the TRN and photo description (if there is one with the photo) on the page.
Thank you for your help!
Victor
Thu Aug 21, 2014 1:51 pm
TRNs need to be written on the front of the photo, as you understand now. Use folders/envelopes (with the same TRNs written on the outside) in order to keep from seeing the target photo when preparing to run a session. Remove all text from anywhere on the photo page. You can leave the target's name (if it has one) on the photo next to the TRNs as long as it's precise and correct and doesn't contain additional info other than a name.
See my feedback on your last post, especially about cramped ideograms.
Remove all the incorrectly prepared targets from your blind pool.
Maybe do one more practice target or two before moving on to DVD-2 if you want. We'll pick back up then.
Sat Aug 23, 2014 8:10 am
Tiger74,
Have done as you recommend: All incorrectly prepared targets removed from blind pool and replaced with correctly prepared ones. One more session completed, following (or at least trying) your instructions. No comments yet but once I have feedback, I'll move on to Disk 2. Thank you again for your help.
Sincerely,
Victor
Tue Aug 26, 2014 1:33 pm
[ Time : 0.119s | 13 Queries | GZIP : On ]
