It is currently Tue Jan 22, 2019 2:13 pm
 Post DVD 4 - Practice session – 03
Post Post DVD 4 - Practice session – 03
Hi all,
This blind target session is from the recommended post "RVRobot Bootcamp" – 4172/6227
viewtopic.php?f=20&t=2582
I have been really trying to stay focused and in structure lately. If I can stay focused it seems like the data comes more naturally – even the AOL’s don’t bother me, like they are part of the package. It seemed like I was able to make better contact with this target.
Here is my new session based on the above TRN...
Thu Dec 18, 2014 7:17 pm
Post Re: Post DVD 4 - Practice session – 03
s3[X] - Missing 'round' in the sketch. Every word has to be depicted EVERY time.
S4[B] - 'Sweetness' should be in the Sensory Column
I suspect there is a bit too much being put into the analytical sketches 'spontaneously'. Some of it seems a bit excessive.
Everything else is groovy, man.
Structure is looking good.
Keep at it and Keep Posting it!
Wed Jan 14, 2015 5:39 am
Hey thanks!
Under S3[x], I have a few small semi-round items - so I assume you mean if a dimensional descriptor is to go into S3's then they need to be clear and obvious (maybe larger)?
I appreciate the help.
~Nathan
Wed Jan 14, 2015 5:29 pm
Round is Round, and semi-circle is Arching, Arcing, or Arch.
Whatever gets recorded down in Stage 3 must be sketched, analytically, in to the sketch.
Everytime.
I have concerns that you may be adding in a lot of things into the sketch, spontaneously. Although, normally, not an issue to add things spontaneously occasionally; excessive amounts, in every sketch, should be avoided.
You want to train your unconscious to give you everything needed into the dimensional column in Stage 3, and not to just give you image impressions or excessive perceptions after the fact; i.e. when they are not recorded in word form first.
Hope this clarifies this a bit better.
Wed Jan 14, 2015 8:58 pm
[ Time : 0.120s | 13 Queries | GZIP : On ]
