It is currently Sat Aug 08, 2020 9:17 am
 kfa's Practice Target [8224/9087] for review
Post kfa's Practice Target [8224/9087] for review
Having restarted the course in earnest, any critique would be greatly appreciated.
Many thanks to kfa for providing the work.
Fri Jan 02, 2015 3:38 am
Post Re: kfa's Practice Target [8224/9087] for review
Welcome back Eric,
I would spread out and keep one stage per sheet of paper. Your stage one ideograms are far too scrunched together.
Try building up more of a solid signal line in your stage fours. Be sure to get at least 7-10 perceptions in the sensory and dimensional collumns before you jaunt over to the right side of the matrix. This is most likely why there was very little accurate data in your T's and I's. That and the fact your just starting up again. It'll come back just fine.
The Jovial perception should have been in the AOL/s column and single tick marks: 'Jovial'.
There's a few nit picks for you, but your session looked quite fluid and looks to be in good shape. i would try to move a tad bit faster, but things are with in the known parameters.
Keep at it and Keep posting it...
Fri Jan 02, 2015 7:01 am
Greatly appreciate your critique, Daing Maing.
Since restarting, I have been having some trouble with (T) and (I) data. Specifically, way too much (I) with very little of everything else. Will definitely implement all of your instructions in these areas.
Thank you, once again.
Sat Jan 03, 2015 1:21 am
[ Time : 0.106s | 13 Queries | GZIP : On ]
