It is currently Wed Jul 28, 2021 3:05 am
 How to Transition from Base Session Break into Resume for S6
Post How to Transition from Base Session Break into Resume for S6
Is the sequence below an accurate description of the Session Flow, of an Advanced RV Session? Secondly, in what manner should one transition/resume into the S6 after Base Session Break?
1. Run Base Session (about 40 minutes), then Session Break.
2. Continue (Resume?) Session by performing S6 Drawing and (S D AI EI T I AOL AOL/S) Data (about 10 minutes).
3. Write S6 Data on S6 Drawing (or continue into other Target Movements and/or Element Explorations)
Fri May 10, 2013 6:47 pm
Post Re: How to Transition from Base Session Break into Resume fo
Keep in mind that we always have to start with a S1 / ideogram sequence to re-connect with the target.
Personal RV Coaching and Consulting:
PM or email me for more information
Fri May 10, 2013 8:39 pm
...Yes, and also, whatever S1 prompt (and subsequent ideogram) you are using to resume the session should be done at least twice to ensure successful reconnection.
Mon May 20, 2013 4:33 am
Does the post Site Template work need to be done same day while the Signal Line is still alive or can it be reopened with the accompanying T R N on a future day?
Carolina....In my mind.
Sun Sep 10, 2017 10:33 pm
I don't see an issue with it, as long as you resume with an aspect or at least stages one through four on the aspect you left off on.
Mon Sep 11, 2017 4:51 am
"While the signal line is still alive"
Classic...thought I'd heard or seen everything before.
Carry on.
https://video.search.yahoo.com/search/v ... tion=click
Mon Sep 11, 2017 10:29 am
[ Time : 0.141s | 11 Queries | GZIP : On ]
