It is currently Mon Mar 25, 2019 7:46 pm
 effective s6 cue question....
Post effective s6 cue question....
what is the most useful cue in s6??
for instance ,like from 10meters above the target ssbp....
is there a cue like same view of what the target photo is actually seen in our eyes in s6?? i mean same view, angle of photo....not far from target...
thanks
Tue Mar 26, 2013 9:58 am
Post Re: effective s6 cue question....
You're mixing up different things. Stage 6 is not the same as a follow-on movement prompt, which is not the same as a cue.
What is the most useful? Not sure it is useful to try and generalize at all. It really depends on the target, apart from that within target classes there are obvious commonalities. And of course there is the standard prompt to zoom in on something on your ST.
Tue Mar 26, 2013 10:15 am
thanks i understood...
but..would you teach me your cues in s6???
or others...the most commonly used cue....
i wanna try the cue..... :lol:
thanks....
Tue Mar 26, 2013 10:26 am
Again, it is not a "cue" which initiates S6. And what best to try depends on what it is you want to know. There are several threads in this section that describe how to do it (e.g. here), suggest to do a little homework and then ask specifically if something confuses you.
Tue Mar 26, 2013 10:47 am
thanks.... :D
Tue Mar 26, 2013 11:01 am
Methinks, the poster has confused S4/6 [movement] with cue.
S6 movements are based off the session details and what you are trying to flush out. Less mental mastur...(K) and more RV.
"Danger, Will Robinson! Danger!"
Wed Mar 27, 2013 8:03 pm
Profile ICQ
The cue is the Matrix search term.
TRNs and everything else (including movement exercises) are prompts.
Wed Mar 27, 2013 8:09 pm
[ Time : 0.092s | 11 Queries | GZIP : On ]
