It is currently Mon Apr 22, 2019 6:50 am
 S6 Drawing
Post S6 Drawing
Do you list S4 data (AI, EI, T, I) on the S6 drawing like you do with a base session site template?
Thu Apr 04, 2013 5:26 am
Post Re: S6 Drawing
Yes
Thu Apr 04, 2013 5:34 am
Post Re: S6 Drawing
Thank you
Thu Apr 04, 2013 7:44 pm
Post Re: S6 Drawing
Can an s6 drawing be done in session, like right after s4 of an aspect, or only after a ST is done, from an element?
Mon Jul 22, 2013 2:36 pm
Post Re: S6 Drawing
Generally, high-level tools are best employed after 40+ minutes of time-on-target.
www.mindmush.com
Mon Jul 22, 2013 3:48 pm
Post Re: S6 Drawing
when using a map to locate a target, can that map be reused for other different target work, or does the matrix associate that map with the first target work? or can it be reused as long as the map is not marked?
Sat Aug 10, 2013 6:09 pm
Post Re: S6 Drawing
Not exactly sure what your setup is here...
www.mindmush.com
Sun Aug 11, 2013 3:29 am
[ Time : 0.073s | 11 Queries | GZIP : On ]
