It is currently Thu Jan 23, 2020 8:22 pm
 Timing & space bodys
Post Timing & space bodys
This is just an idea, will it work? here it going -
Could I nail the timing of a future event by RVing which planet the new Pluto probe "New Horizons" is Nearest to? the probe his a traval time of around 12 years.
When:
Europe/Next deadly terrorist attack/nearest preceding recognizable event
Europe/Next deadly terrorist attack/Pluto probe New Horizons/location/previous solar system planet/Most Visible Feature
Europe/Next deadly terrorist attack/Pluto probe/New Horizons/location/Nearest solar system planet/Most Visible Feature
other project cues:
Topical search:
Next deadly catastrophic event
Where:
Next deadly catastrophic event/present location
Next deadly catastrophic event/present location/nearest significant feature
Next deadly catastrophic event/present location/nearest recognizable feature
When:
Next deadly catastrophic event/nearest preceding recognizable event
Fri Feb 10, 2006 3:26 pm
I'll have a go, and quite possibly make a fool of myself. ;)
Saying "Present Location" to me indicates that the "Next Deadly Catastrophic Event" exists somewhere NOW. In other words, you're asking for example "Where is the next deadly earthquake, right now." Which doesn't really make sense.
Also saying "deadly" is subjective. If one person dies, then it's deadly. Do you mean when more than say 3000 people die? "Catastrophic" also seems subjective. What does that mean exactly?
I'm not sure if you can use "nearest" as a temporal qualifier. "Near" to me suggests "space" not "time" but I could be wrong.
And as far as using the Pluto probe as a time indicator, that's interesting, but I think your cue is backwards. Instead of basically saying: "this event/where is the Pluto probe", you should be saying (again, basically) "Pluto probe/location/when this event happens". If that's even possible, and I'm not sure why it wouldn't be - IF you phrase the question (cue) correctly.
OK, now a pro will be along in a minute to tell us both that I don't know what I'm talking about, but at least I tried!
Good luck!
Mark
Fri Feb 10, 2006 4:23 pm
Yes, it is very interesting. Let's see what PROs have to say about it.
Mat.
Mon Feb 20, 2006 12:31 am
Profile YIM
Mark is correct. Cues must be structured from the Gross to the General to the Specific to the Detailed. And with each level of specificality, you must be refering to a logical aspect or association with the prior, more general, level.
In the case of an event in the future, it makes no sence to say present location. It would make more sence to first generalize the "cause" (of the event). When you do the session you will determine if the cause is an actual physical thing. If you determine this, you can then add "present location" behind "cause" and do the new session. Hope this helps.
Fri Mar 10, 2006 7:56 pm
[ Time : 0.089s | 13 Queries | GZIP : On ]
