It is currently Mon Mar 25, 2019 8:01 pm
 'Higher level prompt' reference list
Post 'Higher level prompt' reference list
I'd like to compile a list of useful higher level prompts for reference. Please add to the list or correct any mistakes.
General Usage: From the top of [1] something should be perceivable
Large visible objects: From the top of [1] something should be visible
Viewing something from a certain perspective From 100 meters south of [1] something should be visible
Mon May 28, 2007 7:52 pm
Rvrobot, Are you looking for movement type prompts specifically like center, top, front, inside? Or prompts like The nearest recognizable feature of [ 1 ] sbp.? Sorry I'm slow. You can go anywhere from the site template or execute brand new sessions off of it. What kind of list exactly?
Tue May 29, 2007 1:59 am
I guess the sky is the limit. We don't need every possible permutation, but just an idea of how to construct the prompts. For example, I've heard that if you want a lot of EI data, try
From inside [1] SSBP
Essentially, you would pick a different prompt from the list depending on the kind of data you want.
Tue May 29, 2007 10:11 am
Heres a quote from Mr Dames that might be of use
we would never want to execute a movement 'inside the target' -- you cannot know, or have an idea about, what the target is until analysis is complete, or several sessions are run. If the target were a person, and you performed such a movement, then your Stage 2's of 'sticky, viscous, crimson, dark, salty, salty, warm, thumping' etc. might lead you astray, especially as an inexperienced viewer. That is why initial follow-up/exploratory movements of 'from the top of the target' and 'from the center of the site' are preferred.
Tue May 29, 2007 8:08 pm
The most recognizable feature of [1] should be visible
The most unique feature inside [1] SBV
Tue May 29, 2007 8:09 pm
The purpose of element [1] should be perceivable
The function of element [1] should be perceivable
You probably don't need to write the word "element" but I do.
Fri Aug 03, 2007 4:27 am
kocmodpom,
FWIW, the word "element" is portrayed by the bracketing of the number. although it may not be affecting your data retrieval, I would work to always stick within suggested structure wherever possible.
Also, you may want to consider taking the capstone course when another one becomes available. As my memory recalls, Ed went into great detail regarding uses for geometries and several creative prompts that have been used in the past (it's quite fascinating). More can be done than just directional qualifiers of the element itself.
--Angel
Fri Aug 03, 2007 1:25 pm
I did the capstone course in 2004 when the commands were also given verbally hence my confusion on writing exactly what I heard...Thanks for fixing that for me!
My how little details fade over time.
Fri Aug 03, 2007 6:40 pm
Does anyone know when the next Capstone is? I'll buy my seat now. I already bought my seat for the Advanced workshop... I can hardly wait. :D
-Mike
Need Training? PM me.
http://www.rvchronos.com
http://www.thervc.org
http://www.rvgeoloc.com
Thu Aug 23, 2007 4:43 am
Post Re: 'Higher level prompt' reference list
(proposed prompts - not tested yet)
The germaneness of [1] SBP
Wed Apr 14, 2010 8:46 pm
Post Follow-on prompts
After rereading some classic threads on target geometry and chain of custody such as
this one by the Major
this one by David Rosetta
and another from the Major
I have concluded (rightly or wrongly) that one can successfully use a target geometry follow-on prompt such as, 'from 2 target diameters west of [1] SSBV" without losing chain of custody of the target since you are still at the target site, whereas employing a higher-level prompt such as "the source of [1] SBP" will cause one to lose chain of custody and require a full new session since it is a new physical target site.
Now let's suppose that you are working off of an idea template instead of a physical site template. Are there higher-level prompts that will act as an equivalent "idea geometry" (analog to target geometry) that can be employed on an element without losing chain of custody and forcing a full new session?
Wed Apr 14, 2010 11:17 pm
[ Time : 0.103s | 11 Queries | GZIP : On ]
