It is currently Tue Mar 26, 2019 6:29 pm
 question on using S6
Post question on using S6
Hello,
I have a question on S6 usage. It is briefly discussed on DVD4 and I have found a little info about it in various posts but not enough to give me a more clearly defined "format" for usage.
Let me explain; let's suppose that I have a S3 analytical sketch labeled S3[X] that is clearly a "structure" and in my S4[X] I have listed tangibles as: "structure" and "building" (the quotes are being used here only in this post for clarification). How would I extract more dimensional data to render a high quality sketch of this "thing"? Would I simply pull out a blank sheet, write S6[X] and proceed to sketch or would I need to write a prompt, as was done in the DVD?
Best regards,
Mike
Need Training? PM me.
http://www.rvchronos.com
http://www.thervc.org
http://www.rvgeoloc.com
Mon Jul 23, 2007 11:25 pm
You could try different vantage points.
For example: From 100 meters south of X something should be observable.
Wed Jul 25, 2007 4:41 am
[ Time : 0.255s | 13 Queries | GZIP : On ]
