It is currently Tue Sep 17, 2019 11:29 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
 3. How does Remote Viewing work?
Post 3. How does Remote Viewing work?
The Remote Viewing protocol is what gradually trains the unconscious to provide information regarding a target in a specific sequence of data. As you write down the data obtained, you become more connected with the target thereby gradually providing increasingly detailed information. This information is then translated into sketches and drawings.
In remote viewing theory, everything in the universe exists as a pattern of information within the collective unconscious, or what is sometimes referred to as the "Matrix." Remote viewing simply allows you to tap into this phenomenon and to transfer a particular pattern to your conscious awareness.
Like much of modern quantum physics, this explanation challenges our common-sense notions of cause and effect. But the bottom line is that trained remote viewers hit their "targets" with at least 80-90% accuracy.
It should be noted that within the Remote Viewing community, "viewing" is considered a metaphor instead of a literal description; what actually happens would more accurately be called "perceiving." Indeed, remote viewers must learn to bypass their rational thoughts in order to allow their unconscious to work. And though it makes use of the unconscious, Remote Viewing is the rigorous, repeatable, scientific collection of information.
http://www.LearnRV.com
Fri Apr 08, 2005 9:24 am
[ Time : 0.145s | 11 Queries | GZIP : On ]
