It is currently Sat Apr 20, 2019 2:40 am
Post new topic Reply to topic  [ 91 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Open search & timeline tool
Post Re: Open search & timeline tool
P0 - Terrorist-caused explosion on familiar bridge; material falling into H2O below & lots of smoke coming from explosion. Very deliberate. Missile may be part of this somehow? ? ?
Timeline: August 30th to October 11th, 2017
NF
Sat Sep 02, 2017 4:06 pm
Greetings folks,
I have been investigating qualifiers to "Open Search". For my most recent above Open Search I applied "Next" to Open Search. This was done the following day from the above session in order to keep it locking into relative position to the Open Search; and before the 1st Open Search could deliver.
And indeed, the 2 Site Templates were materially different. The following is from Next Open Search:
https://photos.app.goo.gl/x2preDNpbS4avJgk1
https://photos.app.goo.gl/uTOj5tRkkGCYtSU02
The Next Open Search seems to be referencing an earthquake. I suspect the Next Open Search is showing the Mexican earthquake. However, if Open Search and Next Open Search really do deliver in a linear sequence, maybe there is a larger one to come.
This poses an interesting question: does does Open Search/Next Open Search line up results in a linear fashion; or does Open Search/Next Open Search triage/stack the priority of events in the same time period? I guess you could use the analogy of parallel vs. sequential processing here, though it's an imperfect analogy.
At the very least, it appears as if Next can be applied to Open Search to create an effect. I will only trust it when I can identify both events and repeat this several times.
Regards,
Nobodysfuel
Fri Sep 22, 2017 7:44 pm
Greetings folks,
The October 11th Open Search window has closed. But it has crossed my mind that a likely candidate may have just snuck through in overtime.
"An explosion at an oil rig Sunday night near Kenner, Louisiana, left at least seven people injured and one missing as of Monday morning. Two of the rig workers injured sustained critical burns and others sustained trauma from the blast, which happened in Lake Pontchartrain, about 20 miles north of New Orleans. A search-and-rescue mission is still underway to find a missing eighth worker."
http://news.nationalgeographic.com/2017 ... 22513719=1
Lake Pontchartrain has a prominent causeway going straight across it. And this oil rig is somewhat bridge-like. Others had chemical storage underneath. And I got stuff falling into the water. Lots of smoke and flames were prominent. The wild card here is that the target was a "very" deliberate act, and time will tell on that one.
As to why the Matrix chose this for Open Search results for 4 viewers and not Hurricane Harvey (Texas), Puerto Rico destruction, or Las Vegas shooting in the same time frame is beyond me.
If this story really is the target, it may have legs.
Nobodysfuel
Mon Oct 16, 2017 11:38 pm
Hey Folks,
I have been busy for the past 6 months or so but getting back to RV shortly.
These are the results of "banging off the rust" pair of sessions.
Tangible common to both sessions:
Raised grit/fibers
Filaments of fire
Shelf
Peak/point
Rock
Heat: pot/flames/charred mat
Overflow/flow
Machine
Rock
Fragments
People
Intangibles common to both sessions:
Open-up-hole/breech
Battle/loss life
Open up hole/point of entry
Collapse/drifting/back-the-forth
Alert/practice/Drill
Motion common to both sessions:
Out
Swirling
Down
Fast left
Up
Data summary on a napkin: Conical peak with swirling mass high above and hovering fast moving machines above.
Discussion: There is a prominent vehicle here moving through the middle of this scene. It involves surveying. But there are lots of other references to rescue. So there may be both topics going on here: such an unusual/unique thing that it needs to be understood & at the same time people are being rescued.
P0 - Large volcanic eruption; significant loss of life; major rescue effort
P1 - Large volcanic eruption with an airplane flying through, surveying or being damaged itself
Timeline: September 16th - to - October 28th, 2018
Nobodysfuel
Sun Sep 02, 2018 6:35 pm
Hi Nsfuel, could you post the ST with the conical peak, please?
Tue Sep 11, 2018 7:55 am
Okay, these links should work:
https://drive.google.com/file/d/1-z4D_d ... sp=sharing
https://drive.google.com/open?id=1xdCuI ... qdHCMGEB1l
https://drive.google.com/file/d/1-cF6NK ... sp=sharing
https://drive.google.com/file/d/1SFy1Bz ... sp=sharing
NF
Wed Sep 12, 2018 4:04 pm
This might be it:
JAKARTA (Reuters) - A tsunami caused deaths when it hit a small city on the Indonesian island of Sulawesi on Friday after a major quake, collapsing buildings and cutting off power, officials said, although the exact number of casualties was not clear.
The tsunami up to 2 metres (six feet) high struck beaches as dusk fell in Palu, a sleepy but growing tourist resort, and the nearby fishing town of Donggala, closest to the epicenter of the quake 27 km away, officials said.
https://www.yahoo.com/news/quake-strike ... 04639.html
Nobodysfuel
Fri Sep 28, 2018 8:40 pm
In my first ST, I got waves and shifting tectonics. It may be that I made a postulating error by means of visual error. Perhaps these are waves coming towards the "viewer" from the horizon and not down from above.
Anyway, this recent tsunami sure looks like a strong candidate so far.
Nobodysfuel
Sat Sep 29, 2018 5:56 pm
The plot thickens. . .
https://www.freep.com/story/news/world/ ... 507607002/
A volcano erupted Wednesday on the same island in Indonesia where an earthquake and tsunami last week killed at least 1,400 people.
The eruption of Mount Soputan on Sulawesi island in central Indonesia prompted authorities to warn of possible lava flows and ash clouds that could impact air travel. Evacuations were ordered for those living within a few miles of the volcano. . .
Nobodysfuel
Wed Oct 03, 2018 1:54 pm
Hi folks,
So I have just done another Open Search and results are different, so the previous one has occurred. After much news watching, I do believe the Indonesian tsunami and volcano were the most likely candidates for that Open Search.
FYI - the next one is NOT a volcano.
I will post over the next couple of weeks.
Nobodysuel
Thu Oct 18, 2018 8:38 pm
[4164/0028]Open Search
October 2018
Base session 1
https://drive.google.com/open?id=14QuVR ... fd9wIBDJ9c
https://drive.google.com/open?id=1XcjfT ... IYZk2pSaXT
The site is a high, thick, dense round container, holder, fork, and drain. There are clear conduits entering into it from multiple directions. Something exits it from below, spreading out over a wide area. This container is like a pot and like draft-liquid. It makes me feel curious and interested. There are people here who feel wary and nervous. Important concepts here include: shelf, storage, element, chemistry, loose, away, and escape. Something about how a substance exits this container is not normal.
Element [1], the container: is a structure, enclosure, container related to fragments and fragrance. It is a very big place like a pot and well localized. It makes me feel dull but other people here are watchful. It is a drain and is localized-specific. This container drips and is like open-heart surgery associated with dig and excavate.
https://drive.google.com/open?id=1ynRoB ... Y-4io04e22
Element [2], the boundary of the container: this area contains fragments, debris which are cracked and casted off. These things make me feel bored. They are parts of flowing debris associated with overflow and spill. There is liquid here which has been severed. There is a lot of dynamic motion at this edge.
https://drive.google.com/open?id=1rvwW1 ... QE6OtqlLCO
Element [4], the clearly defined conduits entering into the container: a very long a straight tube related to manufacture, ingredients, and purposeful addition. It makes me feel curious and makes other feel watchful. It is a hose associated with leading, and placing ingredients. It is a flow associated with chain of ingredients.
https://drive.google.com/open?id=1uCj8v ... 8AAEaqUFIL
Element [5], the word “Element”: this is special ingredients, pieces related to chemical, hold off, slows reaction, and improvise. It makes me feel bored. It is a drain and fluid associated with look over, inspect, and quality. There are many small round objects here bonded to each other, flowing to and fro, and accumulating in a flow towards the bottom.
https://drive.google.com/open?id=1DgVvV ... v0WlzpCqqr
The 2nd most important aspect of the site is a long line of fragments and debris. It is like a track, like molasses, and also like a glacier. This line of fragments spreads out over a very wide area. It makes me feel bored. People here feel bored and attentive. Important concepts here include: slow-moving, chill-out, cooling, and flow.
Element [3], the spreading out ‘track’ of debris: this is a swirling liquid and a molecule which is a portion and like a lagoon. It makes me feel dull. It is a vast area associated with regulate, mixing phase, and ingredients. There is swirling down and spreading out here over a vast area.
https://drive.google.com/open?id=1cONW4 ... fPh7MC2th6
The 3rd most important aspect of the site are back-and-forth undulating movements which are frequency, barriers, edges, boundaries, and flakes. This boundary is like a shelf and also like a saw. It makes me feel mild interest. People here feel watchful. Important concepts here include: loss, depress, lower, lessen, break off, particlize, ripping, and fragmentation.
500 Meters to the West of [X] SSBV
Clear conduits entering into a container high up. Something exits but also spreads out over a vast area.
https://drive.google.com/open?id=1Nts2g ... AZW4sehYmh
Nobodysfuel
Tue Oct 23, 2018 2:02 pm
Base session 2
https://drive.google.com/open?id=1VFXQd ... oVJ82hMVs0
https://drive.google.com/open?id=1aunaL ... OOubbH2abz
The most important aspect of the site is a round structure which is a pot like percolation and associated with liquid-flow. It is a big flow which makes me and other people feel bored. There is dripping liquid here and a grill associated with order, process, demand & supply and semi-firm liquid. There is something coming out beneath it or at the bottom.
The 2nd most important aspect of the site is a mess associated with non-ordinary leaving. It makes me feel wary and demoralized. People here feel unimpressed. It is an open hole associated with drain-fluid. It is an oval hole associated with fluid-outtake. And there are fragments here associated with leftover. There is back and forth motion here and spreading out and down over a very wide area.
The 3rd most important aspect of the site is a force, energy, and a cooker which is like a macerator associated with hold in place. It is a basket and it makes me, and other people here, feel mildly nervous. There is a dynamic liquid here associated with order in place. This is a very big place associated with overflow. There is back and forth and swirling motion in an ordered pattern.
Center of the site SSBP
At the center of the site is a dam and flowing water associated with breech and damage. It is a hollow tube associated with flow. It makes me feel mildly alarmed. People here feel bored and wary. It is a very big tube associated with drainage. It is a drain associated with overflow, regulate, draft, and peak. There is controlled downward motion here but also spreading out and layers or ripples below.
https://drive.google.com/open?id=1tIHS2 ... XOk2aik8yf
Nobodysfuel
Tue Oct 23, 2018 2:04 pm
Discussion & Postulates
This is a spill or leak. It is an unintentional spreading out of a chemical or elements over a vast area. The vast area is repeated often, leading me to think this is air, sea, or space, rather than land.
It’s perhaps important eventually but boring and slow in the short term: moves like molasses and emotions are pretty blasé. It may not make the news. This is very unusual for an Open Search; they are usually eye-catching.
There is a tight “disturbed” type motion here in ripples. It is associated with force, energy, macerator, mess and fragments. It could indicate an earthquake. Or it could signify ripples and waves of water. Or it could be something else all together.
Possible Postulates (1st draft)
P0 - Oil tanker leak
P1 - Dam overflow causing chemical release
P2 - Earthquake causing chemicals to be spread into sea or air
P3 - Pressure leak in spacecraft
P4 - News or scientific discovery about pollution
Timeline: November 1st to December 19th, 2018
I will refine postulates over the coming week or 2.
Kind regards,
Nobodysfuel
Tue Oct 23, 2018 2:08 pm
Base session 1
The most important Tangibles of the site SBP
Circular hollow device, structure & container with tiny particles around it, associated with batch, leaving, and open-haul. It makes me feel watchful and others feel unimpressed. Tight dynamic ripples emanating below/beside one side of the device/structure/container associated with lower, descent, fragmentation. This is a hopper and a rip associated with lack and perforation. There is wide spreading out from one side.
The most important Intangibles of the site SBP
This is a downward dynamic oozing and spreading down, or from background to foreground, of small pieces over wide area. It is a wreck and material associated with ooze, flow, & regular. There are fragments, pieces, parts, associated with drift. There is drifting layered debris associated with order out of control. There are chemicals here associated with lower and less. There is a drain here. This situation makes me feel bored and others unimpressed and bored.
Discussion
Ripples beneath the circular hollow object appear consistently and they may indicate that this situation occurs in stages or repeats over a long time. And this may also explain the unimpressed emotions, as people's shock eventually habituate to demoralization, kind of like what occurred during the Louisiana BP oil spill; shock and "help" ("Hey, let's chop up golf balls and stuff 'em in!"), gave way to resignation.
Nobodysfuel
Fri Oct 26, 2018 11:31 pm
Postulates (2nd draft)
P0 - Prolonged, difficult to remedy, oil or chemical refinery leak
P1 - Prolonged, difficult to remedy, oil tanker spill
Nobodysfuel
Sat Oct 27, 2018 7:35 pm
Here is a potential candidate:
https://www.nbcnews.com/news/us-news/no ... ch-n936126
Nobodysfuel
Fri Nov 16, 2018 3:14 pm
Greetings folks,
This was a strange one and I had been watching the news closely without being convinced this open search had occurred.
However, after reviewing my work, I do believe this event was the recent Indonesian volcanic eruption of Anak Krakatau and the following tsunami. It was 4 days past the time window, but the estimates of open search results occurring between 2 to 8 weeks is an observational pattern, not a fixed rule.
https://www.washingtonpost.com/world/20 ... 295e83da10
The big error in my results was in postulating; my interpretation that this was a man-made leak was wrong. I took the roundness of the archetypes too literally and deceived myself into thinking they must represent tubes and drum-type containers.
Both base sessions depict this event quite well. The tsunami was caused by a mud slide or a rock shelf collapse and that is clearly depicted in both sessions. “Shelf” and “peak” are also mentioned.
I will use this as a valuable learning experience to improve my analysis.
Merry Christmas and all the best to all of you for a hopeful 2019!
Nobodysfuel
Mon Dec 24, 2018 8:54 pm
Hi folks,
Happy 2019!
So, I have made my most recent attempt at an Open Search. This one is pretty easy to postulate, so there is only one base session and limited follow-on.
https://drive.google.com/open?id=1hcPQd ... 1BmEH1uMjw
https://drive.google.com/open?id=1g_zGN ... ikkOdq3kIQ
Data summary
The most important aspect of the site is a crater which is a big peak, and a mountain top associated with peak & valley, and top & below which makes me feel upset and sad and makes people here feel scared and watchful. There is something emanating quickly from the peak and there is something undulating and spreading out in all directions above. There is something spreading down, outward, and in all directions from this emanation. This thing is a dribble which is like drool associated with errant, wandering, and loose. It is a flow and a bubble associated with overflow.
The 2nd most important aspect of the site is a hollow peak and dripping stuff associated with chief, principal, and standout example. There are life forms here who feel nervous, nauseous, and shocked. These are repeated swirling undulations through and over at least one peak in one direction. This is an overflow associated with ordinal.
Further investigation [1] indicates a vast cloud associated with high altitude moving in all directions over a wavy landscape all of which makes me feel wary and nauseous. There are life forms here who feel nauseous and shock and it is associated with cataclysm, tragedy, and epic. It is a mess associated with overflow and epic.
https://drive.google.com/open?id=16MtpO ... EGnl4Pq5UC
Continued investigation [2] indicates fragments, debris, and organic matter associated with order & chaos, gone in a flash, and very big catastrophe. This situation contains fast moving substance spiraling and twisting over a wavy landscape. This situation makes me feel nauseous and there are life forms here who feel nauseous. There is a layered mess here associated with fracas. There is pumice here like rice particles associated with valve outlet and release.
https://drive.google.com/open?id=1MgBfl ... _GDbXfH3L8
The 3rd most important aspect of the site is a flow, which is also a cloud and pumice associated with overdraft. It makes me feel nauseous and shocked. Life forms here feel upset and scared. This situation spreads out in all directions and down into valleys below. It is associated with shelter, big mess, raised & lowered, and big fracas. Viewer note: “immense” is one of the Dimensions; I rarely, if ever, get immense, so this may be noteworthy.
Discussion
I have remote viewed a nuclear reactor core and also murder scenes. The negative AIs and EIs I felt for [A & B], [1], and [2] were some of the strongest I’ve felt. It was a choking, nauseous shocked feeling. I’m not sure what this means.
I received quite a few terms in the Intangibles column which I didn’t error trap, that seem to indicate this could be a big deal: tragedy, cataclysm, epic, very big catastrophe, chief, principal, standout example. I didn’t feel they were AOL, nor did they feel like hyperbole, so I just have to go with the data. I also received the intangible of “ordinal,” which refers to ranked number: 1st, 2nd, 3rd, etc., as opposed to currency and decimals. I got the sense that this was implying this was a Top 10 of its kind sort of thing.
Postulates
P0 – Major volcanic eruption and debris outflow over land
P1 – Major volcanic eruption and tsunamis over ocean and land
Timeline: January 19th to March 2nd, 2019
Be well,
Nobodysfuel
Sun Jan 06, 2019 10:46 pm
Greetings Folks,
As the vesting period of this open search has arrived, I decided to dive into some quick follow on work. In fact, I did a complete 2nd session.
Generally speaking, there does not seem to be a tsunami in further follow on work. There may be a mess of liquid stuff, but I don’t believe this is ocean-based. However, it’s more than just a volcano. It may be associated with a tectonic event, as there is an open fissure (pool) emptying something onto the earth (lava?). The mountain peak has a “collapse” and there is definitely a “before & after” to it; it could be something like a Mt. St. Helens.
There seems to be a lot of ash in this session, spreading out and pooling down into mountain valleys, so it seems to be a pretty mountainous region. This region has the same negative AIs for me.
My main reason for going back was to explore emotions. Throughout the session I felt the same very strong negative AIs and EIs (nausea, choking, shock). But I tagged 2 groups of people on the ground to further investigate. I’ve always wanted to improve my sensitivity with AIs and particularly EIs.
One group of people are near a distressed building with ash billowing nearby. AIs and EIs are both strong and negative.
The 2nd group of people I tagged on the ST generated absolutely NO AIs and EIs of interested, blissful, and relief. There is swirly stuff in the sky. I take this to indicate they’ve perished.
I found this emotional exploration very interesting and good practice.
Conclusions: this is more of an ash-based volcano with a tectonic element, loss of life, and an air quality headache for some.
Nobodysfuel
Sat Jan 19, 2019 10:28 pm
Hey Folks,
This open search may have just occurred:
"BRUMADINHO, Brazil (Reuters) - Brazilian firefighters said on Saturday that at least 34 people were killed when a dam burst at an iron ore mine owned by Vale SA , as rescuers continued to search for hundreds still missing."
https://www.yahoo.com/news/brazil-rescu ... nance.html
This upper atmosphere volcano postulating doesn't fit, but the material flowing over valleys sure does. The EIs of shock, choking, and nausea sure fit suffocation.
A very sad situation.
Nobodysfuel
Sat Jan 26, 2019 9:49 pm
Hey folks,
So yes, indeed, the Brazil tragedy was most likely the previous Open Search:
https://www.cbsnews.com/news/brazil-dam ... 019-01-25/
I did an Open Search session and target results have change, so the above has vested.
I was pleased with the above session results and postulating. Half of my P0 was correct: "debris flow over land".
I would have liked to have seen "dam" in my session work and perhaps "chemicals" mentioned somewhere. I will do more post-analysis.
At first blush, the next Open Search appears to be a pipe burst/piercing in an industrial setting with hot & cold with political consequences. I will do more follow on before posting.
Nobodysfuel
Sat Feb 02, 2019 4:26 pm
[7030/2557]Open search – February 2019
Data summary
The most important aspect of the site [X] is a place which is technology and a descending pipe. It has a big tear in it. It is associated with fracture and turn off and it is a groove which makes me feel wary and hungry. There are people here who feel watchful. This is a hole associated with drainage, bored and is like soup. A lack of attention causes an error here. This is a dormant section associated with little used.
The 2nd most important aspect of the site [A] is an encircled place and a tank which is full of a flowing mass associated with chemical and focus (of attention). This situation makes me feel wary. There are life forms here who feel watchful. It is a big tank which is like a pool associated with drain and hollow out. There is a grill here at the bottom associated with barter, negotiate, leverage, and escape and it is like a big piece.
The 3rd most important aspect of the site is a cylindrical shape with something shooting out of it. It is a place and an object associated with drain and it makes me feel watchful. People here feel wary and watchful. There are fragments and something drips on a tube. This is a piercing associated with unusual circumstance, away, and leaking. It is a big leak associated with depths.
S6 [1] is a large space and fragments. This situation is brief and fast. There is land here. There is a conglomerate of material here and is like an icicle and also like a stalactite.
https://drive.google.com/open?id=1ZLqL6 ... i_YzrmSlcc
https://drive.google.com/open?id=1kF6LY ... fjXWhXQUTN
https://drive.google.com/open?id=1Qt0LA ... vPjpja0Q23
Discussion
There is a pierced or cracked pipe or vessel leaking here.
This is an irregularity at a man-made place. There is some inattention and some rarely used equipment leading to this. It is a pipe or vessel which has been pierced or cracked open. Something flies out fast and quickly, probably at high pressure. Some of it goes up into a cloud. Some of it drips and bubbles below, traveling a long distance. Under normal circumstances something is added to the top of this pipe or into this segment of pipe. The stuff in the pipe is a combination of things, like a soup. There are consequences resulting from this: barter, negotiate, leverage.
More to come. . .
Nobodysfuel
Tue Feb 05, 2019 12:33 am
[7030/2557]Open search – Follow-on
Element [2] “Descending pipe”
S3 analytical sketch depicts pipe with downward flowing, swirling through the area and things moving down and to the left.
This is a thing and a segment which is like a tap involved in marshal, control pressure, flow control, setting flow and it is also like a timer. There are life forms here associated with steering. There is a big empty space around this thing and it is like Martian landscape. This is an oval tap associated with error, hesitate, try again, depth, and penetrating multiple times.
Element [3] “Negotiate”
S3 analytical sketch depicts hollow rectangular box with circulating inside and energy or light emanating from the corners. There is a flow of particles out of it down, or from background to foreground.
This is a place and an enclosure which is like a coffin associated with death, structure, and lack of control. There are people here who feel cynical and unimpressed and is like a forked tongue.
This situation is also associated with merit, deserve, and over-depth (as in someone is in over their heads). Someone here is resigned. It is a protective enclosure associated with fallout, negative publicity, descending into chaos, party politics, and steady hand.
Element [4] semi-circular line near “Big Tank”
https://drive.google.com/open?id=1tlTxp ... cwOPLFC-W6
This is a place, and enclosure, and a sturdy place associated with segments and piercing. There are fragments here. There are life forms here who feel unimpressed. There is expensive metal here and a hull. Something is overdone and it is like being overcooked. Something is radiating outwards here and is vastly overdone. This is a dense sheath.
Discussion
This seems to be a safety lapse, with multiple unsuccessful attempts to fix. People may feel cynical and unimpressed because they’ve been promised that it was safe but turned out not to be. This could be an industry with an already bad reputation simply reinforcing its stereotype: nuclear, pharma, chemical, petroleum. Cooling may have failed in an industrial process or something is overcooked. Workers or locals may have to be evacuated.
Nobodysfuel
Tue Feb 05, 2019 3:26 pm
On another note: here are some videos of the Vale dam collapse in Brazil:
https://www.youtube.com/watch?v=sKZUZQytads
https://www.youtube.com/watch?v=g9DjQuF2Lok
It goes so fast it stops a locomotive.
Interesting that it created so much dust above. That is perhaps what I had thought was ash.
Nobodysfuel
Tue Feb 05, 2019 9:22 pm
Element [5] Liquid descending into pipe at top
The S3 analytical sketch shows droplets entering this pipe. They are tiny droplets or perhaps a chemical bond. There is a lot of flowing something above this site. There is energy or heat radiating from the top of the pipe and also from the liquid drops.
This is a place, a reservoir, and a hollow tube associated with frequent, often, improvised, and maintenance. There are people here who feel bored and ambivalent. This situation is associated with Metric calculation error. It is a chamber and there is coolant associated with refrigeration and loss of cooling which is like a cooling tower and also like Baked Alaska. Melting and storage are important concepts here.
Element [6] on the horizontal line below near “Depths”
The S3 analytical sketch depicts something long and deep, tapered and spinning (sort of like a drill bit) and something flowing through the scene from left to right.
This is a thing and a device which is a hollow tube which is like a diamond tip. This is a special device associated with extract and take away. It makes me feel mild interest. There are people here who are attentive and watchful. This is a hauler and a drill associated with belly up to be served. There is a force here association with extrusion which is like a burp.
Element [7] on the top of the pipe or vessel
https://drive.google.com/open?id=1uskJk ... 3aCGWgzMXz
This is a thing and a place which is a hollow tube and big tube and also a pipeline associated with drilling, waste, purposeful injection and is like fraking. It makes me feel mad. There are life forms here who feel angry. This is a process and a servo associated with automatic and remote-controlled. There is a force here associated with open up and it is like a tap for a keg.
S6[7]
This is a peaceful place, a hollow tube, and there is mist associated with management, aiming, and guidance. It is like champagne and the explosion below is like a bell.
https://drive.google.com/open?id=1BTkPB ... XXrIutxGJr
S6[7 – Inside]
There are hovering particles here inside a hollow tube associated with heat. There is metal here. This place is like a lake.
https://drive.google.com/open?id=1G_tYf ... NrxsHKtACR
Discussion
The liquid entering this pipe involves pretty advanced chemistry and heat exchange. There is an operator error or miscalculation due to inattention.
People beside the pipe are angry. The pipe is an automatic process but may be going wrong due to the addition error above. The pipe keeps up high pressure for some reason and pushes below, but it bursts. It controls the flow of something which may be pushed into a natural environment, but it has gone wrong. Flow inside this pipe is quite complex with specific flow separation, injection and mixing.
With depths, something is being extruded into this area and is flowing away. It serves or provides something for people.
Nobodysfuel
Wed Feb 06, 2019 1:43 pm
[ Time : 0.124s | 12 Queries | GZIP : On ]
