It is currently Sat Mar 23, 2019 11:14 pm
Post new topic Reply to topic  [ 20 posts ]
 Making preceding events personalized
Post Making preceding events personalized
If I wanted to know what the most recognizable preceding event in my personal life would be before a major desaster can I use this nnnn/nnnn The Killshot/ my most recognizable preceding event?
Tue Apr 02, 2013 9:29 pm
Post Re: Making preceding events personalized
Hi Tsunami,
Killshot is just a nickname used to refer to the sunburst that will wipe out modern civilization as we know it. Do a forum search to get a better idea. My suggestion for your question is to run an open search.
TRK
PD. Then hurry to find your sanctuary.
Sometimes I see RV as Steganography, where the Matrix codes the information it is giving us in a milliard wonderful ways, reminding us that we are just part of it, and rendering one and infinity as two properties of the same supreme existence.
Wed Apr 03, 2013 1:39 pm
Use your name and most recognizable event as cue qualifiers
Wed Apr 03, 2013 5:25 pm
Indeed, "killshot" is not a valid matrix search term in the context you want and hence will give you absolute junk. A simple google search of "killshot definition" will confirm that.
Use the base cue used in Project Noodle without changes as your starting point.
Thu Apr 04, 2013 10:02 am
"Danger, Will Robinson! Danger!"
Thu Apr 04, 2013 6:37 pm
Profile ICQ
Ok so I'm confused
nnnn/nnnn
The Killshot/ persons name/ most recognizable preceding event
That is a nonsense cue? Ed has said The Killshot is a valid cue and that the matrix will pick it up?
Fri Apr 05, 2013 5:20 pm
I never said any such thing. Quite the contrary; I stated that the term (in reference to a sequence of solar events) is a/my neologism.
Fri Apr 05, 2013 5:35 pm
I apologize Sir. I thought you mentioned it was a valid cue. Definitely do not want a nonsense cue! So if I want to explore the killshot what's the cue? And if I wanted to qualify it to make it something I'd recognize as a preceding event in my own life like, I get in a car wreck or something a week before.
Note: ( I have disaster cues DVD do I need to go back and look at that?)
Fri Apr 05, 2013 5:54 pm
Read more carefully. The answer is already in this thread.
Fri Apr 05, 2013 6:12 pm
Next/ catastrophic solar event/ persons name/ most significant preceding event
Fri Apr 05, 2013 6:23 pm
Nope.
Fri Apr 05, 2013 7:19 pm
I'm confused because that's what I thought you told me to do earlier in the thread. I need help I really not getting it.
Fri Apr 05, 2013 8:50 pm
[xxxx/xxxx]
Earth/ next catastrophe/ persons name/ most recognizable preceding event
1.I don't know what to call the killshot in "matrix language"
2. I'm still not sure about my initial question which was whether or not you could personalize a preceding event to something that will happen to that person so that they know "oh #%£€! It's time for me to get out of dodge and join so in so at their safe zone".
Fri Apr 05, 2013 9:15 pm
Poor Tsunami .. here is your reading assistance.
Sat Apr 06, 2013 2:39 pm
Kocmodpom and RV Robot have already given to you the answer.
Firstly, you aren't using the exact Project Noodle's cue. Start from there. And later:
"Cuando bordeamos un abismo y la noche es tenebrosa, el jinete sabio suelta las riendas y se entrega al instinto del caballo."
(Armando Palacio Valdés)
Sat Apr 06, 2013 5:12 pm
Profile YIM
I finally figured this out! Thanks for tolerating me! Haha.
Mon Apr 08, 2013 4:10 am
You should probably post your latest guess to make sure you really have figured it out.
Mon Apr 08, 2013 7:36 am
Planet Earth's next global natural catastrophe-cataclysm/name of person/most recognizable preceding event
Or is it : /most recognizable feature
I plan to give this to a friend blind. Let me know. Thanks for following up.
Tue Apr 09, 2013 4:20 pm
In this instance I prefer Bubba's most recognizable preceding event
Remember that while "event" seems to work properly for future, unnamed targets, you should never use it on named targets, future or especially past cues (ref. the Major regarding this topic).
Tue Apr 09, 2013 11:50 pm
Copy. Thank you.
Wed Apr 10, 2013 12:20 am
[ Time : 0.128s | 13 Queries | GZIP : On ]
