Re: Topical search on a locally defined term
wormwood wrote:
[xxxx/yyyy] <company-name-here> / <project-name-here> / "Bugzilla Bug 1275" / optimum solution
That's a good idea of where to start, I'd say. Give it to someone as a blind target and see how it works. But off the top of my head, I would encourage the use of target reference material in this case, to firmly establish what you are asking the Matrix about. I would print out some sort of hard copy of the bug in question. Preferably some sort of 'cover page' that has the official name of the bug as well as the author's notes about the symptoms that you mentioned. If they wrote anything about a possible cause, I might delete that part. Underline the part that says Bugzilla Bug 1275. Then I would use
[xxxx\yyyy] Bugzilla Bug 1275/optimum solutionWrite the TRNs/cue on paper and include it in a folder with the TRM. Write the TRN's on the outside of the folder. Here's a couple of other cue ideas to be used with the same TRM:
[xxxx\yyyy] Bugzilla Bug 1275/primary cause[xxxx\yyyy] Bugzilla Bug 1275A cause could very well show up in that second cue, if you are able to identify it. At the very least, you'd get an idea of how the Matrix identifies a term such as this, which could help you in the future with software/engineering RV issues.
I'm wondering if there may be an alternative, 'holistic' approach to this, similar to an optimum health trajectory for your company's project. If I come up with anything, I'll come back.
I'm interested to see how this turns out. Keep us posted.
