It is currently Wed Jan 23, 2019 7:15 am
Post new topic Reply to topic  [ 17 posts ]
 Optimum use of RV cue
Post Optimum use of RV cue
Greetings,
I am curious about my optimum method for making money using Remote Viewing. Or at least the optimum way to use Remote Viewing in my professional life.
I was thinking of the following cues:
* my optimum use of Technical Remote Viewing
* my optimum money-making method using Technical Remote Viewing
Or perhaps,
* me/Technical Remote Viewing/optimum trajectory
The last cue may be best; money-making would be factored in, or ignored if it's a moot point.
Thanks for your advice,
Nobodysfuel
Sun Jul 31, 2016 9:19 pm
Post Re: Optimum use of RV cue
Optimum vocation
Optimum remote viewing target.
Optimum trajectory
Sun Jul 31, 2016 10:12 pm
Hey Norbert77,
Thanks for your input. At various time I've done the cues your suggest. Most while taking pro training from RVRobot. All great information and I take it all under advisement.
However, I guess I'm presently interested in business development opportunities for RV.
Nobodysfuel
Mon Aug 01, 2016 1:32 pm
You seem to be framing this cue problem as a way to make TRV monetize itself through you. Would that not be the 'house of mirrors' phenomenon? -- You plan to view yourself running TRV sessions "professionally" and that will somehow reveal information about the actual tasks and activities you need to cultivate in order to generate economic leverage? Isn't that the hallway of What is the target of the target, of the target.....
Somehow you will need to find your optimum activity for capital accumulation. If you could discover it with a single TRV session, would you be disappointed? Are you stuck on looking for the most lucrative way to chase some moving target with TRV all the time?
My most lucrative TRV application. ??
Guessing you're probably considering how to best prioritize your time, given the desire to allocate significant chunks to RV, and hey wouldn't it be great if THAT activity was the primary abundance generator.
But, if that is something like teaching RV or winning $500/wk in a pick-3, then it probably wouldn't satisfy your expectation of the potential scale of such 'business development opportunities', right?
Rope the horse then put it in front of the cart.
Wed Aug 03, 2016 5:26 am
Interesting point. Thank you for your comments.
I don't so much care what brings the financial results (3-pick lottery or a full blown consulting business) as long as it's optimum for me.
"lucrative application" is not bad; I will think on this more.
Nobodysfuel.
Thu Aug 04, 2016 2:18 pm
Not sure if this is 'kosher', but then how about
My optimum TRV-supported enterprise ?
Any rabbi's willing to bless that?
Fri Aug 05, 2016 1:50 pm
Enterprise has a lot of definitions.
I would counter-offer with:
My optimum TRV-supported commercial enterprise
Yet, somehow this still seems a bit unwieldy to me.
Though I might want to re-write the cue order:
My optimum commercial use of TRV
But I'm still "feeling" this is a bit too much.
My optimum use of TRV? - this may or may not include financial objectives, depending upon what the future holds.
I guess I'm looking the optimum way to go pro with RV and make a living with it.
Nobodysfuel.
Fri Aug 05, 2016 2:13 pm
Then I'd suggest
My optimum TRV business-venture
Fri Aug 05, 2016 2:41 pm
Thanks cbutter,
I think that's pretty good. That's pretty much what I'm after.
I'm also going to look at my optimum use of TRV because I'm interested in that as well. And if they turn out to be the same, that will tell me something also.
Thanks again,
Nobodysfuel.
Fri Aug 05, 2016 5:11 pm
You're welcome! It's a great exercise, thank you. Will definitely be interested in your findings if you care to share.
Sat Aug 06, 2016 3:54 am
Listen up, troops:
These are faulty RV cues/incoherent Matrix search terms. Employ instead these general/generic, tried-and-proven/time-tested ones, first:
My optimum investment
The optimum investment
Then, use those project results to refine and generate a follow-on RV stratagem, if necessary.
Sat Aug 06, 2016 4:48 am
nobodysfuel wrote:
... Or at least the optimum way to use Remote Viewing in my professional life.
Or perhaps,
Like as Ed has said above...
Listen up, troops:
I would recommend and have had positive, coherent results from:
My Optimum Wealth Trajectory or My Maximum Wealth Trajectory(be weary of outcome)
I also would steer you in the direction of something like:
Colorado Pick 3 / Next winning number / optimum remote viewing method - technique (still a very raw cue for dependable results)
I have not personally finished the requisite six topical search results for the term: 'remote viewing'. Also, please take this suggestion with a grain of the proverbial salt. Although, the experience of a forty five minute journey will out weigh the gravitas of the destination; for some.
Good Hunting...
Sat Aug 06, 2016 7:25 am
Thank you, Major.
DaingMaing,
Thank you – very interesting.
1. Are you implying that all topical searches require 6 base sessions to flesh out properly?
2. Are you implying that the term Remote Viewing is not recognized by the Matrix and therefore shouldn’t be added to a cue?
Nobodysfuel
Sat Aug 06, 2016 8:58 pm
1. As a basic rule, yes. That is six sessions with follow on work.
2. No, I am not implying that. I have only completed one of the six requisite sessions to understand what the term is according to the matrix. I would say go ahead and see what happens, but keep in mind that you are using an untested cue. It may produce garbage or something close to it. Vague-ness does happen from time to time when trying out new cue search verbiage, so be aware when it comes time to analyze your hard earned work that you are working with something that is unknown.
Sun Aug 07, 2016 6:40 am
DaingMaing,
Do you do 6 base sessions for regular work? Or is it only for topical searches?
Nobodysfuel.
Mon Aug 15, 2016 8:39 pm
nobodysfuel wrote:
DaingMaing,
Nobodysfuel.
That is usually a topical search sort of thing. It is something Ed has inculcated in his course/students since the start of the LRV DVD course(perhaps even in the Psi-Tech days), Art Bell interviews in the mid-2000's, and all over these forum to this date.
It is used when you don't know what the matrix may make of any given term. It is also used when you are not sure what it is you are asking about the given term(s).
Now, in a very involved project you will want several base sessions on several different aspects, views(target geometries), and the like(significant features nearest the site) of any given real world target. It is needed to flesh out the full picture of any given target, location, or event(past, present, or future).
I hope this helps.
Tue Aug 16, 2016 6:30 pm
Thanks for the clarity DaingMaing.
I don't run topical searches often, but I will keep this in mind.
Nobodysfuel.
Thu Aug 18, 2016 4:14 pm
Users browsing this forum: Exabot [Bot] and 1 guest
[ Time : 0.152s | 12 Queries | GZIP : On ]
