It is currently Sun Oct 25, 2020 4:31 pm
 Question: Lottery Name
Post Question: Lottery Name
I live in North Carolina, the lottery name is Carolina Pick 3. Should I use North Carolina Pick 3 or Carolina Pick 3?
Tue May 10, 2011 2:44 pm
Post Re: Question: Lottery Name
Interesting. South Carolina has a Pick 3 game too, don't they? Is it also called Carolina Pick 3? Here in Arizona the game is simply Pick 3, but the ticket prints out with the header Pick 3 ARIZONA LOTTERY. That's the name I use in my cue. If the header on top of the ticket is Carolina Pick 3 I think I would use that name just as it appears on the purchased lottery tickets.
Tue May 10, 2011 7:31 pm
Grab a copy of the lotto rules and find out what the official name is from the pamphlet. Most also have a website with a PDF version.
Tue May 10, 2011 7:40 pm
I'm using FULL, exact version so Matrix will absolutely be certain.
CA LOTTERY SUPER LOTTO PLUS
Let me know of your successes!
Mon Sep 12, 2011 4:28 pm
I was under the impression (from the Lottery DVD) that it should read "Arizona Lottery Pick Three." Is that incorrect?
Fri Oct 28, 2011 5:15 am
You will only know if it works if you try. Experiment.
Remember, uncharted territory never has signs pointing which way to go.
Fri Oct 28, 2011 6:50 am
I did. Ran it exactly that way on my first attempt, so I'm just trying to determine what correct protocol or SOP is.
Fri Oct 28, 2011 6:50 pm
[ Time : 0.221s | 11 Queries | GZIP : On ]
