It is currently Tue Sep 22, 2020 9:21 am
 Dimension words " around " ,"wide"...
Post Dimension words " around " ,"wide"...
i'm sorry to ask again...professional viewers...
apart from "mass" related words...in analytical sketch
Some word like " wide" , "around" is super complicated as a line drawing
in one way or another.. :oops:
i used to use this words as a arrow line in the bottom of the site...
(ex <----- wide(some place..)------>, <--------around------->)
is it correct ??
and i can't go there right now...
because here in south korea... :cry:
Fri Sep 18, 2009 2:10 am
Post Re: Dimension words " around " ,"wide"...
For me, I think the worst part of a session is interpreting dimension words as line drawings, and I can't give much advice. But I can tell you what I have, myself been warned against. Don't use arrows unless motion is involved. So, you can only use arrows for those words if your 'wide' is meant to indicate a 'wide' range of motion of some sort, and your 'around' is indicating something moving 'around'.
Fri Sep 18, 2009 4:00 am
thanks very helpful.... :D
Fri Sep 18, 2009 10:48 am
Hi,
The first sketch on the left is depicting "movement around".
The sketch on the right depicts "around".
The sketch on the bottom of the page depicts "wide".
Enjoy!
Fri Sep 18, 2009 11:24 am
1. Can you draw something that is 'wide'? (~65% of the time)
2. If not, Can you label something that is already there as 'wide'? (~30% of the time)
3. If not, can you label some empty space on the sketch as 'wide' (~5% of the time or less)
Apply this logic for any dimensions that you have difficulty with (wide, dense, heavy, around, open, vast, etc).
Fri Sep 18, 2009 12:54 pm
thanks.. :D
very helpful.... :)
Fri Sep 18, 2009 1:45 pm
[ Time : 0.138s | 13 Queries | GZIP : On ]
