It is currently Fri Mar 22, 2019 8:26 pm
 Correct HARV Terms!
Post Correct HARV Terms!
Hi, I'm doing a bit of research into HARV displacement. Simply, would anyone know the technique differents between the terms below, and if possible their causes mental and (Matrix vs Psychic) pathways:
Displacement
Psi-missing
Morphing
Bleed-through
thanks for the replys :wink:
Thu Mar 07, 2013 9:18 pm
Post Re: Correct HARV Terms!
In general:
Morphing is to bleed-through as psi missing is to displacement. However, the 'David Rosetta' syndrome is not factored into this relationship -- especially in the laboratory. (Indeed, it is ignored)
Mon Mar 11, 2013 1:34 am
thanks Ed, I understand the terms now...
Is it possible to describe the effects of Morphing/bleed-through and psi-missing/displacement on an HARV session?
Mon Mar 11, 2013 3:16 pm
[ Time : 0.071s | 11 Queries | GZIP : On ]
