It is currently Fri Feb 22, 2019 2:56 am
 TRN 4635.4869
Post TRN 4635.4869
Here is a scan of my session on TRN 4635.4869.
Please point out what I did wrong, what I did ok, and what I hosed up horribly.
Respectfully,
Sat Dec 27, 2008 3:09 am
Post Re: TRN 4635.4869
boveele,
Write aol and underline your aol word. Make sure you are dropping your pen.
Example:
AOL
aolword
Freehand sketch:
Put your labels on your aspects, not off to the side or above them. Write them on the line. X is your best example of this.
S3 does NOT get specific identifiers ie nouns such as 'Structure, floor, stadium, etc".
Also try not to use labels in s3 unless you have problems drawing the dimension.
Keep labels in s3 to a bare minimum.
At that point, "Structure" is AOL.
Identifying the aspect at the beginning of the stages has a way of reconnecting you to that part of the target. Very useful for beginners.
From the top of [X], S2 of [X] etc...
Review the DVDs over and over again. You will learn something each time.
Sat Dec 27, 2008 9:02 am
JayBird,
Thanks for pointing out what I messed up.
I will underline the AOL from now on, then drop my pen, and then get moving again.
I will make sure the labeling for X, A, B, and C are on the lines, not next to it.
I will reduce the amount of labels in the S3 sketches.
I will use the freehand sketch identifiers in the Stage 1 of X as well Stage 2 of X, and Stage 3 of X, and so forth for each item from the freehand sketch in the following pages.
Thank you kindly for pointing me in the right direction. I do appreciate it.
Respectfully,
Sat Dec 27, 2008 4:59 pm
[ Time : 0.098s | 12 Queries | GZIP : On ]
