It is currently Tue Mar 26, 2019 6:29 pm
Post new topic Reply to topic  [ 10 posts ]
 The process of generation about T in s4
Post The process of generation about T in s4
as long as i know in s4,
once you have enough data, T data pops up in our mind...
(ex: tall,glassy,noisy,boxy,rectangle,heavy...etc then...building!!!!)
and then write down the T data that come to one's mind...
is it correct???
in my practice session, there are very few T data poping up in my mind....
i am very worried,whether there are something i badly screw up or not...
if it is because the lack of practice...let me know...
thanks...as always
Fri Apr 12, 2013 4:24 am
Post Re: The process of generation about T in s4
You may guide the flow of data by moving your pen to a different column. This acts sort of like a 'request' for a different type of data.
Fri Apr 12, 2013 10:17 am
'Prompt'
Fri Apr 12, 2013 3:04 pm
first of all ....thanks...i'm not sure i fully understand that...
But...that means when "data cluster" comes then i move my pen in T column(or Ai or Ei)
and request to my mind.."What it is?" then write down the proper word that come to your mind summarily....
is it OK?? :)
Sat Apr 13, 2013 3:54 am
No. But, we can serve you much better and correct your confusion if you post your sessions.
Sat Apr 13, 2013 4:01 am
as ed told you..
i attach the s4 session i used to process....
mostly, i used to do in that way...
is there any problem..please consult me!!!!
and i have another question
i've posted question about s6 process...
i assume that there need two sheets of paper..
one is like s4 template..
the other is a blank paper to draw...
is it correct???
Tue Apr 16, 2013 1:10 pm
Why would you just write down 'thing' in the T column if nothing was coming to mind? What if the aspect is not a thing, but an idea or a concept?
Tue Apr 16, 2013 8:31 pm
ah~~i see...thanks for your advice...
then when there are nothing that comes to mind on T column,
then i have to write down "-(nothing)", is it right??
and i found out if some words come to mind,while i write down on S,D data...
as i posted, i used to write down that word on T...
but there were many cases where that word was wrong , not correct on the target...
there was cases that word(T data) did not exist on the target...
i think it is also like AOL....
is it right??
or does T data come to be more accurate while i am trained??
sorry to ask many questions...... :oops:
Wed Apr 17, 2013 7:04 am
No. You probe a column to test if it delivers a percept, but don't force yourself to write something down at all cost. That only gets your creative imagination to fill in the blank. You write "thing" in the T column, when there is a tangible thing, that you can't further specify at the moment.
Wed Apr 17, 2013 8:57 am
thanks...kia... :)
Fri Apr 19, 2013 4:19 am
[ Time : 0.170s | 13 Queries | GZIP : On ]
