It is currently Tue Mar 26, 2019 6:25 pm
 Proper nouns
Post Proper nouns
Hello. I was rewatching DVD2 last night and I was wondering about T's and I's. This seems to be the place where the highest level of concepts show up in the entire RV process. Is it possible for proper nouns to appear in these columns or would that be considered AOL even though it is Stage 4? Thanks.
Thu Dec 21, 2006 4:25 am
Yes, in the aol column.
Think about it... a proper noun during a session infers a, "certainty," about the target, which you are NOT allowed to have during a session.
Fri Dec 22, 2006 10:02 pm
Good point. I will remember it.
Fri Dec 22, 2006 10:40 pm
Post Re: Proper nouns
The types of tangibles and intangibles should be of the type: "structure", "building", "mechaism", "maching", "tool", "commerce", "library", "skyscraper", etc ..
As David indicated, if your analytical mind gets involved it will provide a proper name and should be considered an AOL - However, it is very important to surgically discet all data that comes in to place it in the correct column and sometimes proper nouns do have a place in S4 but only in the AOL/S column.
For example, in a moment a single seamingly percept of structure (of course followed by corresponding S & D sensory data) could be instantly followed by building, skyscraper, "like john handcock building". An inexperienced viewer might merge them into a single item and through it into the AOL column when atually each of those 3 items should be in columns of T, T, AOL/S. This is the time where the analytical mind does provide some useful information as it knows the target is "like" something it has been made aware of in it's past.
Sun Dec 24, 2006 8:06 am
Thank you for clarifying
Sun Dec 24, 2006 9:48 pm
[ Time : 0.091s | 11 Queries | GZIP : On ]
