It is currently Wed Aug 21, 2019 2:08 pm
 Ask for viewing
Post Ask for viewing
Hi, I've been away from practicing rv for a while. I'm now in a situation where my lack of practice and the front loading and emotions of associated to my target would make any viewing I could do inaccurate. Years ago I did do some readings for members when they asked. Are there any members that could do a yes/no type reading for me?
Sat Nov 10, 2018 1:02 am
Post Re: Ask for viewing
No, there aren't -- nobody here does 'psychic readings.' Highly structured, highly disciplined, combat effective remote viewing only.
Sat Nov 10, 2018 1:27 am
I wasn't asking for a 'psychic reading' The viewing I was asking about would be just like those in the cd course material. I just don't entirely trust my ability at this time or for this subject. I think it may be best if I put this one in a pile of practice targets and try to avoid the front loading that way.
Thank you for the reply.
Sat Nov 10, 2018 5:17 am
You specifically said, "readings" -
https://en.wikipedia.org/wiki/Psychic_reading
It would appear that you meant RV session.
https://en.wikipedia.org/wiki/Garbage_in,_garbage_out
https://www.edglossary.org/rigor/
If you articulate the problem, Pat, I will walk you through the formulaic RV steps/strategy to solve it. Don't stick it in your training target pool without first ironing out the associated correct cue(s)/implicate Matrix search terms.
In the event that you simply seek your "yes/no type reading," then I refer you to the penultimate cosmic source for that: https://en.wikipedia.org/wiki/Magic_8-Ball
Straighten up and fly right - LearnRV
Sat Nov 10, 2018 6:46 am
I did say reading, sorry for that. I know the words we use are very important in rv and that's a mistake I shouldn't have made. Would it be OK to send you a message about the target and circumstances and go from there?
Thank you.
Sat Nov 10, 2018 4:56 pm
For the benefit of other trainees, the discussion/instruction should be here, in the forums.
Sat Nov 10, 2018 5:43 pm
OK, the cue I was going to use is "(subject name), daughter of (mother's name and father's name), alive or dead." No brackets when I use the names.
Thank you for below. I'll try those tonight when I have some alone time.
Sat Nov 10, 2018 5:48 pm
TRV SOP:
[nnnn/nnnn] (name)/now
[nnnn/nnnn] (name)/present location
Sat Nov 10, 2018 6:07 pm
Thank you very much for your help. I'm so out of practice I don't know if I can trust my session results so I'm going to start again from the beginning. The target I'm looking for is my sister. She went missing in a different city 2 weeks ago and it wasn't until I was talking to a friend of hers that does dowsing that rv came back to me; as I was discussing the language he used with him when he searched. As said in the financial dvd "will the market go up, away from gravity, or down, toward gravity."
Thank you again.
Sun Nov 11, 2018 4:33 am
PS, thank you for the magic 8 ball link, that put a smile on my face.
Sun Nov 11, 2018 4:38 am
Even if your RV skills were up to snuff, you would not be able to effectively work this project. As I point out in my RV Basic workshops, this is due to the propinquity factor. It shows its teeth in Stage 4 -- you would not be able to dissipate AI to the necessary degree required to continue the session and maintain objectivity. The inescapable, constant 'background-running' AI's of fear ('I hope she's not dead') and desire ('I hope she's alive') would indubitably blackmail the session.
You must therefore pass the task on to a fellow RVer, one whom has neither propinquity nor emotional attachment, vis-à-vis your sister.
Sun Nov 11, 2018 5:07 am
Thank you, what would be an appropriate place to post that?
Sun Nov 11, 2018 5:25 am
Right where you're at, in this selfsame cyberspace boolean electro-dimensional venue thingy-slot. I'm sure there's a few kindred souls here that would lend you a hand. (Those of you whom choose to do so, PM the petitioner).
You'll need to designate the target/s, and assign TRNs to it/them.
Sun Nov 11, 2018 5:40 am
[ Time : 0.099s | 13 Queries | GZIP : On ]
