It is currently Sun Sep 20, 2020 1:54 pm
 A rule of thumb question
Post A rule of thumb question
Hi,
I have a question regarding S6.
When a team of viewers are blind to the target and a viewer decides they want to do an S6 what would be the prompt if any that they should use?
As an example; if I am the PM I know what the target is. I may know its relative size, dimensions, etc. But the viewers do not have that information, though they may have some perceptual data that indicates size. But if they are executing a session for a target that is hundreds of feet in size or lightyears across and decide to do an S6 with a prompt: From 35 feet above the target SSBV...... well it doesn't quite make sense to do that does it?
So what would be a good rule of thumb if a viewer decides to do an S6 and is totally blind to the target?
Perhaps, just write S6 at the top of the page and begin to draw?
thanks,
Mike
Need Training? PM me.
http://www.rvchronos.com
http://www.thervc.org
http://www.rvgeoloc.com
Fri Jul 11, 2008 8:36 pm
Post Re: A rule of thumb question
This is not strictly a S6. It is a target geometry. Because of the inherent problem you stated, we use this kind of prompt:
"From two target diameters north of the target, SSBV"
Doesn't matter whether the diameter exists as angstroms or parsecs.
Problem avoided.
Fri Jul 11, 2008 9:17 pm
Excellent!!! Thanks Ed.
Fri Jul 11, 2008 9:21 pm
I'll cover the subject of target geometries in much greater detail during the fall RV workshops.
Fri Jul 11, 2008 11:45 pm
[ Time : 0.106s | 13 Queries | GZIP : On ]
