It is currently Fri Aug 07, 2020 1:40 am
 HARV Morphing.
Post HARV Morphing.
I'll post this here, since it's probably most related to the financial markets stuff.
I've run 3 HARV sessions in a row today and have had the same results in all 3.
My S3[x] analytic sketch points one direction and my S4[x] descriptors, at the beginning describe the photo matching the S3[x] drawing, but then swaps over halfway and starts described the alternate photo.
Possible courses of action from here?
1. Run additional iterations until the results are more conclusive.
2. Weigh the photo with S3[x] analytic support over the other. (the drawing is 100% indicative of 1 photo, with specific details)
3. Take an extended break from HARV.
Feedback would be appreciated.
ps. I have also been consistently running blind enigma targets inbetween my HARV sessions, since I started on this project.
pss. I'm using the HARV method described by Proviewer at the workshop in September.
Fri Jan 20, 2012 9:32 pm
Post Re: HARV Morphing.
Remote Viewing is a quantum mechanical process. Superposition of probabilities occur in all RV but are amplified in HARV applications.
If you want to know more, target the cause of your error.
Fri Jan 20, 2012 9:52 pm
That's a good point, I might just do that.
Although, the target is fixed, it is not a future's prediction. This is also after about 15 extremely accurate HARV sessions.
Fri Jan 20, 2012 10:01 pm
Yea, 15 HARV sessions? Say goodbye to novelty and hello to my old drinking buddy ennui! To reiterate that even alternating between full and HARV is not enough:
http://www.rvcommunity.net/viewtopic.php?f=30&t=4207&start=18
May I ask the specific application?
Fri Jan 20, 2012 11:10 pm
I'll answer that via PM.
Thanks for the responses Kocmodpom.
Fri Jan 20, 2012 11:30 pm
I am glad that you brought this subject matter up though. Most people often chose to demand an overreaching solution that likely doesn't exist. So they continue to beat their heads against the wall reinforcing the definition of insanity that is, doing the same thing over and over again expecting a different result, instead of changing how, or how often they do something.
It is so much easier to accept that target morphing and forward displacement exist and adopt a strategy that compensates for their existence as well as the factors that accentuate them rather than to ignore them entirely and blame the setup.
You my friend are already ahead of 99% of the populace in moving forward in spite of the difficulties.
Sat Jan 21, 2012 12:34 pm
[ Time : 0.110s | 13 Queries | GZIP : On ]
