It is currently Fri Sep 18, 2020 11:17 pm
 Accident or Intentional
Post Accident or Intentional
If one wants to find out if the destruction or damage to any certain object, place, person was intentional or accident, what would be a good solid cue?
I might try the following:
[ nnnn / nnnn ] object / destruction / cause
[ nnnn / nnnn ] object / damage / cause
Any suggestions would be appreciated. Thanks for your time and interest.
Seek the truth.
Mon Sep 22, 2014 1:57 am
Post Re: Accident or Intentional
The "cause" is already known. The question is actually, is the damage/destruction "intentional or accident?" Is there a proper cue to answer the "intentional or accident" question?
Seek the truth.
Tue Sep 23, 2014 11:48 pm
Okay.
Does anyone think this would bring us closer to answering the above question:
[ nnnn / nnnn ] object / damage circumstances
As always, thanks for your input.
Seek the truth.
Sat Sep 27, 2014 5:33 am
Have you actually tried any of the above? If intent was part of the cause, it might just show up.
I looked in the dictionary just now, as in German there is a single and often used word for the one (or that which) causes something. 'Causer' would be the direct equivalent, but it must be rather awkward in English because I don't know it used anywhere, always see it somehow paraphrased. However, the entry also offered 'origin'. Never considered it in this context, but maybe it works.
Sat Sep 27, 2014 8:18 am
Yes.
[ nnn1 / nnn1 ] object / destruction circumstances
[ nnn2 / nnn2 ] object / destruction
[ nnn3 / nnn3 ] object / destruction / cause
Each gave fair details on the life form present. [ nnn1 / nnn1 ] object / destruction circumstances, gave the best EI data on the life form. From this ST I will do a follow on session with the life form as [ 1 ].
Bottom line is, there is enough data to make a conclusion as to the original question.
In the future the [ 1 ] follow-up from the ST would be the proper method to proceed.
Thanks again for your input. It is appreciated.
Seek the truth.
Tue Sep 30, 2014 9:30 am
Being sure a person is responsible for the damage, you can target their 'uppermost thought' at the moment it happened. In case you're working front-loaded, or on top of that even are emotionally invested in the case, anything to do with EI is very difficult to trust though.
Tue Sep 30, 2014 12:55 pm
[ Time : 0.111s | 11 Queries | GZIP : On ]
