It is currently Wed Jun 03, 2020 12:15 am
Post new topic Reply to topic  [ 16 posts ]
 MIA codename WHIPPOORWILL
Post MIA codename WHIPPOORWILL
[0511/0831] Stacy Peterson's skull/present location
https://petersonstory.files.wordpress.c ... terson.jpg
I am currently working this case (RV Geofix), and plan to be in the field on the project sometime during April or May (after my Lindsey Baum in situ foray).
I want Brett Stuart, Morgan Farrel and the rest of my best to give this a shot. (Don't fool around with the cue/Matrix search term)
Publish your work here, in this forum. I'll probably invite a few of you to join me in the field (along with cognizant TV news teams) when it becomes time for us to establish 'ground truth' re. this young woman's fate.
http://www.goodreads.com/author/quotes/ ... ant_Conant
http://idioms.thefreedictionary.com/kee ... n+the+ball
Tue Mar 10, 2015 3:04 am
Post Re: MIA codename WHIPPOORWILL
The target is a medium-small, dense and heavy thing made of steel and cast-iron. This thing is old and immobile, in a state of disservice. It seems cramped somehow. It is dark, and there is an acrid smell about it.
There is something nearby that holds, protects and transports. It is stiff, old, and worn, made of canvas. It reminds me of a mat, or a suitcase.
There is also something here that is central to something – the main part. It is considered a household design and is old-fashioned. Something about this makes me think of cinderblocks.
Personal RV Coaching and Consulting:
PM or email me for more information
Wed Mar 11, 2015 2:38 am
bstuart Base Session:
The target is a dense, cement structure. This is an angular place positioned high and over something organized. Something oval and wide is painted red here.
A hollow ramp has been placed-over something here. This is a blue, shiny and metallic reflective sign.
There are many things resting in-between a narrow place. These were thrown and launched and eventually came to rest. These are wet and have been discarded. The things have been placed here and it reminds of something ceremonial.
Holy crap...so much for a project starting gun (did you both happen to 'read my mind') -- you guys are going to put me out of a job!
Respectfully,
Wed Mar 11, 2015 3:06 am
Post To my other RV professionals
At the risk of waxing redundant, heed my advice:
Do not allow these initial MIA team member results to influence your own work -- fight any bias to do so. After turning your skilled RV attention to a coherent Matrix pattern target/TRN, only the output of your own unwavering connection to directed unconscious attention counts. By now, I hope that you have learned how to vector such direct knowledge into y/our operant-conditioned, Earthmind-dimension spectrum.
Wed Mar 11, 2015 4:28 am
The target appears to be a dark and solid object that is under continual use. Some sort of energy source is associated with this from which there is the sending out of something. A maintenance crew seems to be present here.
Also present at the site is some dark thing that is turned on. This is a tool that is servicing something that seems to be failing.
Fri Mar 13, 2015 4:20 am
There is a solid indication (on my end; from my work) that her skull might not be intact. Switch to this refined target cue:
[1465/1780] Stacy Peterson's remains/present location
Fri Mar 13, 2015 6:11 am
The location is an open, outside place that was formed in an apparently unintentional manner. It is highly obscured. There are things, objects here that remind me of a shopping cart or an old refrigerator somehow.
There is a small, narrow place below here that seems inaccessible and unstable. It is dark here and there is a distinctly pungent smell present. There is thick earth and clay here that seems like it’s been contaminated.
There is something here described as a conglomerate of stuff, items. There are a variety of unused odds and ends, scraps here, as well as soil and clay.
Sun Mar 15, 2015 12:26 am
Got it, Morgan. I'm on top of things, also -- but the project may become abbreviated, very shortly. I'll supply target feedback, soon. You'll be able to evaluate your expedited work in light of that.
Sun Mar 15, 2015 12:49 am
http://en.wikipedia.org/wiki/Landfill
Employing quasi (queasy)-contemporary American English vernacular: you guys rock.
Brett, espy/note those cement cylinders in the first aerial, as well as your other site descriptive data.
Anyway, hope that both of you (Farrel/Stuart) maintain -- and continue to develop -- your RV excellence.
P.S. - As professionals and rising-star RV teachers, continue to stay alert in your work; recognize and manage egoic mind-operant attractor pitfalls and slipstreams
Sun Mar 15, 2015 2:03 am
I appreciate the opportunity to work on these projects Ed. It's a shame that the remains appear irretrievable. If you would like me run the second TRN, I'll make time for it tomorrow.
After glancing at the Geofix coordinates, I noticed another similarity aside from the cement tubes used during the construction (sewage?). Notice the triangular ramp that's placed over and the on/off ramp in the satellite image. There are also road signs on that triangular divide if you look at the street view.
Sun Mar 15, 2015 4:40 am
We've got other stuff to do, now, Brett and Morgan.
Keep in mind that, regardless of one's experience, RV (mind-Matrix) cues can also either make or break a project. Additionally, (at the risk of waxing patronizing), always remind your students that RV work is primarily a function of attention -- vs. 'intention' (the Courtney Brown syndrome and David Rosetta factor, notwithstanding).
Ed
Sun Mar 15, 2015 4:44 am
So I assume this project is now closed?
Sun Mar 15, 2015 8:09 am
http://idioms.thefreedictionary.com/miss+the+boat
Sun Mar 15, 2015 12:28 pm
Major Dames, Thank You and everyone on your team, for the work on this MIA. I'm local, so I will be the "boots on the ground" for all the searching in this area. Now that you've "CLOSED" this case, if you'd like all of the info I've gathered over the years, I'd be happy to supply it in a response. I continue to be surprised at how accurate all of you really are. KUDOS! I'm a former policeman who has always believed in using "alternative methods" to locate murder victims. The problem is getting "sane people" to listen. LOL Again, Thanks... ALL of you! Say the word and I'll post everything I have on this particular case. If, for no other reason, than to provide you with some closure. WOW! I'm still freaked out. My respect for what you folks do is unwavering.
"Far better it is to dare mighty things, than to take rank with those poor, timid souls, who know neither victory nor defeat." Teddy Roosevelt
Wed Mar 18, 2015 11:39 pm
Profile YIM
Moderator
Moderator
Femur Man,
On behalf of Major Ed Dames, we would like to ask that you please hold off on posting any more information regarding this case at this time. We have an in-person meeting with the Major tomorrow morning at our production office and we will be discussing this topic with him. It’s possible we may want to get in contact with you for an interview and all of the information you have regarding this case in private in order to produce a short documentary about this case.
We’ll be in touch shortly and thank you very much!
Remote Viewing Products Producer
866-607-8439
Producer - Remote Viewing Products Inc.
Thu Mar 19, 2015 12:13 am
[ Time : 0.236s | 14 Queries | GZIP : On ]
