It is currently Tue May 21, 2019 2:40 pm
 completely lost , memory blank, no connection "guide me"
Post completely lost , memory blank, no connection "guide me"
So far good, getting there , here's my problem , I completed dvd 1 , when i want to draw a analytical sketch of x , I dont know but it seems i cannot connect to back to my unconscious mind which drew the ideogram , and i am having difficulty in drawing analytically to what I wrote down in dimensions , sometimes I dont get dimensions , they are lost , A very narrow window of opportunity to speak to unconscious to draw ideogram then lost it . Well I do good to ok on gotpsi.org rv tests which i use to practice. but its not enough for me . I am lost here guide me to get better.
Wed Sep 07, 2016 2:08 am
Post Re: completely lost , memory blank, no connection "guide me"
Hello, and welcome. A stage three analytical sketch and an ideogram are very different in concept and in execution. In S3 of an aspect, simply refer back to the dimension category from S2, and draw each dimension descriptor as individual components of a diagrammatic sketch.
www.mindmush.com
Wed Sep 07, 2016 3:18 am
Thanks, I will have to re watch the dvd and practice more,
But I am curious to know
a. does all pro and starters get the full correct picture of the target.
b. I only get a part of the picture not full , you see in the dvd - Ed Dames student perform , here he drew the picture of mountain peaks and the house right angle to ground , whereas I got a peak then aol rocket , ice , similarly in gotpsi always I get only a part not full - is this a focus, attention , retention issue , too many things going on in my mind , too busy .
Thanks in advance , way to go for me before ks starts . I cant wait to completely master.
Wed Sep 07, 2016 4:16 am
Welcome!
Yes. In my experience, when you're first starting to learn, you'll get an image flash of a small portion of the target. But it is small. So small, in fact, that you'll never construct the target based on this flash. It's as if it's 3,000 pixels of a 100,000 pixel picture. It's exciting, but will lead you astray if you act on it in your session. This will go away after about 20 sessions and it becomes AOL to the structured viewer. It's a little disappointing, I know. There is a post about this occurrence somewhere on the forum.
Focus on structure. Learn the descriptor list by heart. Practice. Post your sessions on the forum, and let the pros critique you here. If an image comes into your head, it's AOL. The target is not that image. You can't let yourself be thinking in session. To do this, the actions and structure will have to come from shear routine. The structure, when mastered, will come. Almost like muscle memory.
Thu Sep 08, 2016 2:26 am
Vimaljan,
Utilizing psi test's like you mentioned will just slow you down..
Thu Sep 08, 2016 4:22 am
This is true - pick a method, learn it properly, and stick with it. There are no shortcuts.
www.mindmush.com
Thu Sep 08, 2016 8:34 pm
[ Time : 0.115s | 12 Queries | GZIP : On ]
